Configures the tunnel designated router (DR) priority that is advertised in PIM hello messages.
| ipv4 | IPv4 address family (default). |
| tunnel | Specifies the tunnel name. |
| tunnel_name | Specifies the name of the PIM interface. |
| dr-priority | Designated Router Priority for VLAN. |
| priority | Priority value for VLAN (default 1). The range is 0–4294967295. |
The default setting for dr-priority is 1.
The dr-priority option allows a network administrator to give preference to a particular router in the DR election process by giving it a numerically larger DR priority. The dr-priority option is included in every hello message, even if no DR priority is explicitly configured on that interface. This is necessary because priority-based DR election is only enabled when all neighbors on an interface advertise that they are capable of using the dr-priority option.
configure pim ipv4 tunnel accounting dr-priority 10
This command was first available in ExtremeXOS 32.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
